Known Issues in This Release
This section provides details for known issues in this release.
Oracle Utilities Meter Data Management Known Issues
The following are known issues in this version of Oracle Utilities Meter Data Management at the time of release:
Name
Reference Number
Description
Workaround (if applicable)
Reader Remarks and Direct Measurement Processing
37605748
Reader Remark Activities are not being created when using Direct Measurement Processing.
Usage Transaction Correction Processors and Direct Measurement Processing
37605766
Usage Transaction Correction Processor Activities are not being created when using Direct Measurement Processing
Consumption Synchronization and Direct Measurement Processing
37613264
Consumption Synchronization does not work with Direct Measurement Processing
Out of Order Outbound Communications
37328135
Outbound communications that occur within 1 second of each other may potentially be displayed out of order
Deprecated Product Use Metrics Business Objects
32620169
Product Use Metrics business objects have been deprecated
Error handling with Pass Through data with Direct Measurement Processing
37588395
Pass Through Initial Measurement Error Handling with Direct Measurement Processing
Install hot fix
Error handling with Pass Through data with Direct Measurement Processing - Status Mapping
37664161
Pass Through Initial Measurement Error Handling with Direct Measurement Processing - Status Mapping
Install hot fix
Measuring Component Ordering Opt-In with Direct Measurement Processing
37576809
Opt-In Parameters for Measuring Component Ordering with Direct Measurement Processing
Install hot fix
IMD Type Algorithm Parsing Errors
37589032
Parsing Errors in IMD Type Algorithms
Install hot fix
IMD Headers for "Information" VEE Exceptions with Direct Measurement Processing
37589029
IMD Headers for "Information" Severity VEE Exceptions with Direct Measurement Processing
Install hot fix
SOM Field Activity Completion Events Not Creating Initial Measurements
37593406
SOM Field Product Use Metrics business objects have been deprecated.Activity Completion Events are not creating Initial Measurements
Install hot fix
Oracle Utilities Application Framework Known Issues
The following are the known issues in this version of Oracle Utilities Application Framework which may affect Oracle Utilities Meter Data Management at the time of release:
Name
Reference Number
Description
Cleanup Request Type search not working properly on Orphan Deletion Type
37628011
When editing an Orphan Deletion Type request type or when adding one after viewing an existing record, if you try to search for a Cleanup Request Type, it is defaulting the value to the Request Type in context. This is likely not the correct one.
You can work around this by finding the Cleanup Request Type code and copying it into your clipboard, and then pasting that value into the input field rather than trying to use the search.
Alternatively, for an add scenario, you can leave the page and then use the menu to add the request type (without viewing an existing value first).
JSON Lines extract with concatenation is incorrectly creating '*.tmp' files.
37610732
JSON Lines is a newly supported extract format. The format does not produce a proper JSON Document, but rather a list of JSON documents. It means that the whole document does not need to be surrounded with any characters like {} or []. (Unlike the JSON format, where the final document is a proper JSON object or array).
Because of this, when requesting concatenation for a multi-threaded process, the individual threads and the final concatenated file can all have the *.jsnl extension. The code was released with the incorrect logic of using a *.tmp extension for the individual threads. That logic was needed for the JSON format, but not the JSON Lines format. It will be fixed to use the *.jsnl extension for individual threads.
There is no work around needed, but implementations should not be planning any downstream logic that expects the individual thread files for JSON Lines output to have a "*.tmp" extension.
Unable to convert W3C schema to XML
37580078
The issue can occur while calling the toXML() method of com.splwg.base.messaging.impl.json.JSONToXMLJettisonConverter class while running batches.
As a workaround, copy the 'woodstox-core-6.4.0.jar' and 'stax2-api-4.2.1.jar' jars from weblogic installation directory (<wls-dir>/oracle_common/modules) and add them to standalone/lib and tpw/lib folder and restart the ThreadPoolWorker.
Drop ILM Partition Support For All MOs
37653601
Allow Drop Partition Approval Request Creation If Previous One Is Rejected
Approver user should not perform any rejections. If the Drop Partition Approval Request was created in error, have the Requester user cancel it.
