Customizing Configuration Files
To make customer modifications to various configuration files, create a ‘CM copy’ of the template file or user exit instead. This preserves the changes whenever initialSetup is executed; else, the changes to the delivered template files will be lost if it is patched in the future.
Below is a sample procedure to customize the properties file of the SPLWeb web application:
1.	Locate the spl.properties.template in the $SPLEBASE/templates directory.
2.	Copy the file to cm.spl.properties.template.
3.	Apply the changes to cm.spl.properties.template.
4.	Update the application war file with the latest changes:
	Linux:
$SPLEBASE/bin/initialSetup.sh
	Windows:
%SPLEBASE%\bin\initialSetup.cmd
Refer to the Oracle Utilities Application Framework SDK documentation for more details.
