Domain Templates
Configure the WebLogic application server to deploy it. Refer to the Oracle WebLogic Configuration Guide for Oracle Utilities Framework (Doc ID 2413918.1) on My Oracle Support for more details.
Update Domain Home Location
The following update in the configuration indicates if the embedded configuration is being utilized or if the environment is a native installation to WebLogic. When this item is populated in the environment, the delivered base tools will be able to identify that the starting and stopping of the environment are being done under the domain home.
1.	Initialize the Environment: splenviron.sh –e <Environment_Name>
2.	Execute: configureEnv.sh –a
3.	Select Menu Item:     52. Advanced Web Application Configuration
4.	02. Configuration Option:    Domain Home Location
	Current Value <ENTER>:
	The Weblogic Domain Home location, when this parameter is populated you will need to use the native Weblogic tools for maintenance (starting, stopping, deployment, and undeployment).
	Enter Value: <Enter your domain home location>
5.	Once the Domain Home location has been completed, enter <P>.
