Menu Option  | Name Used in Documentation  | Customer Install Value  |
Environment ID  | ENVIRONMENT_ID  | |
Server Roles  | SERVER_ROLES  | |
Oracle Client Home Directory  | ORACLE_CLIENT_HOME  | |
Web Java Home Directory  | JAVA_HOME  | |
**ONS JAR Directory  | ONS_JAR_DIR  | |
Web Application Server Home Directory  | WEB_SERVER_HOME  | |
***Additional JAR Directory   | WLTHINT3CLIENT_JAR_DIR  |
Import Keystore Directory  | KS_IMPORT_KEYSTORE_FOLDER  |
Environment Mount Point  | SPLDIR  | |
Log File Mount Point  | SPLDIROUT  | |
Environment Name  | SPLENVIRON  | |
Install Application Javadocs  | WEB_ISJAVADOCS  | |
Install Sample CM Source Code  | CM_INSTALL_SAMPLE  |
Environment Description  | DESC  |
Business Server Host  | BSN_WLHOST  | |
Business Server Application Name  | BSN_APP  |
Web Server Host  | WEB_WLHOST  | |
Weblogic SSL Port Number  | WEB_WLSSLPORT  | |
Weblogic Console Port Number  | WLS_ADMIN_PORT  | |
Web Context Root  | WEB_CONTEXT_ROOT  | |
WebLogic JNDI User ID  | WEB_WLSYSUSER  | |
WebLogic JNDI Password  | WEB_WLSYSPASS  | |
WebLogic Server Name  | WEB_WLS_SVRNAME  | |
Web Server Application Name  | WEB_APP  | |
This Is A Production Env. And The Client Is Live  | WEB_ISLIVEPRODUCTION  | |
Deploy Javadocs Module  | WEB_DEPLOY_JAVADOCS  | |
Enable The Unsecured Health Check Service  | WEB_ENABLE_HEALTHCHECK                    | |
MDB RunAs User ID  | WEB_IWS_MDB_RUNAS_USER  | |
Super User Ids  | WEB_IWS_SUPER_USERS  |
Application Server Database User ID  | DBUSER  | |
Application Server Database Password  | DBPASS  | |
Batch Database User ID  | BATCH_DBUSER  | |
Batch Database Password  | BATCH_DBPASS  | |
Web JDBC DataSource Name  | JDBC_NAME  | |
Database Name  | DBNAME  | |
Database Server  | DBSERVER  | |
Database Port  | DBPORT  | |
ONS Server Configuration  | ONSCONFIG  | |
Database Override Connection String  | DB_OVERRIDE_CONNECTION  | |
Character Based Database  | CHAR_BASED_DB  | |
Oracle Client Character Set NLS_LANG  | NLS_LANG  |
Batch RMI Port  | BATCH_RMI_PORT  | |
RMI Port number for JMX Business  | BSN_JMX_RMI_PORT_PERFORMANCE  | |
RMI Port number for JMX Web  | WEB_JMX_RMI_PORT_PERFORMANCE  | |
JMX Enablement System User ID  | BSN_JMX_SYSUSER  | |
JMX Enablement System Password  | BSN_JMX_SYSPASS  | |
Coherence Cluster Name  | COHERENCE_CLUSTER_NAME  | |
Coherence Cluster Address  | COHERENCE_CLUSTER_ADDRESS  | |
Coherence Cluster Port  | COHERENCE_CLUSTER_PORT  | |
Coherence Cluster Mode  | COHERENCE_CLUSTER_MODE  |
Import TrustStore Directory  | TS_IMPORT_KEYSTORE_FOLDER  |
OSB Home  | OSB_HOME  | |
OSB Host Server  | ||
OSB_HOST  | ||
OSB Port Number  | ||
OSB_PORT_NUMBER  | ||
OSB SSL Port Number  | OSB_SSL_PORT  | |
OSB Managed Server Port Number  | ||
OSB Managed Server SSL Port Number  | ||
OSB_MANAGED_SSL_PORT  | ||
JDBC URL for Database  | DBURL_OSB  | |
OSB Service Table Schema Name  | ||
RCUSTBSCHEMA_OSB  | ||
OSB Service Table Schema Password  | ||
RCUSTBSCHEMAPWD_OSB  | ||
OSB WebLogic User Name  | ||
WEBLOGIC_USERNAME_OSB   | ||
OSB WebLogic User Password  | ||
WEBLOGIC_PASSWORD_OSB  | ||
Mount Point for OSB Files  | ||
OSB_LOG_DIR  | /spl/sploutput/osb  |
SOA Home  | ||
SOA_HOME  | ||
SOA Host Server  | ||
SOA_HOST  | ||
SOA Port Number  | ||
SOA_PORT_NUMBER  | ||
SOA SSL Port Number  | ||
SOA_SSL_PORT_NUMBER  | ||
SOA Internal URL  | ||
SOA_INTERNAL_URL   | ||
SOA External URL  | ||
SOA_EXTERNAL_URL  | ||
JDBC URL for SOA Database  | ||
SOA Service Table Schema Name  | ||
RCUSTBSCHEMA_SOA  | ||
SOA Service Table Schema Password  | ||
RCUSTBSCHEMAPWD_SOA  | ||
SOA WebLogic User Name  | ||
WEBLOGIC_USERNAME_SOA  | ||
SOA WebLogic User Password  | ||
WEBLOGIC_PASSWORD_SOA  | ||
Specify the Path for XAI/IWS Service  | ||
WEB_SERVICE_PATH  | XAIApp/xaiservert  |
MDM Bulk Request Callback URL  | ||
MDM Headend HTTP Connection Timeout  | 50000  | |
MDM Headend HTTP Read Timeout  | 500000  | |
MDM SOA Request Queue JNDI Name  | queue/BulkRequestQueue  | |
MDM SOA Notify Queue JNDI Name  | queue/BulkNotifyQueue  | |
MDM SOA Command Queue JNDI Name  | queue/BulkCommandQueue  | |
SGG-NMS TestHarness Partition Name  | SGG-NMS_Test  |
JNDI Name of Destination Queue to publish SGG payloads for DataRaker Integration Tool  | DataRakerQueue  | |
Number of records (SGG Payloads) to accumulate  | 100  | |
Max file size for the accumulated (SGG Payloads) file in Kilobytes  | 524288  | |
Specify a time which, when exceeded, causes a new outgoing file to be created in seconds  | 600  | |
Polling frequency of Staging directory for new files in seconds  | 60  | |
Mount point/directory for the accumulated SGG payload file  | /spl/sploutput/staging  | |
Mount Point/directory for the converted XML file to place for DataRaker  | /spl/sploutput/int  |
LG SOA Partition Name  | LG  | |
LG SOA TestHarness Partition Name  | LG_Test  | |
AMI Event Subscriber Output Path  | /spl/sploutput/osb/lg-cim-event  | |
MR_Server endpoint URI  | ||
CD_Server endpoint URI  | ||
CIM_Server endpoint URI  | ||
MeteringServer endpoint URI  | ||
Security policy attached to outbound web service calls to a CIM interface  | sgg/d3_cfs_cim_header_client_policy  | |
Security policy attached to inbound web service calls from a CIM interface  | sgg/d3_cim_token_service_policy  | |
The name of the OWSM policy to use when SOA calls a head end system  | oracle/http_basic_auth_over_ssl_client_policy  | |
The name of the OWSM policy to use when SOA is called by a head end system  | oracle/http_basic_auth_over_ssl_service_policy  |
NES endpoint URI  | ||
SOA partition to which the application is installed  | Echelon  | |
Path to the NES EventManager web service on the head end system  | CoreServices/EventManager.asmx  | |
Path to the NES GatewayManager web service  | CoreServices/GatewayManager.asmx  | |
Path to the NES DeviceManager web service on the head end system  | CoreServices/DeviceManager.asmx  | |
Path to the NES SettingManager web service on the head end system  | CoreServices/SettingManager.asmx  | |
Path to the NES UserManager web service on the head end system  | CoreServices/UserManager.asmx  | |
Name of the OWSM policy to use when SOA calls a head end system  | oracle/http_basic_auth_over_ssl_client_policy  | |
Name of the OWSM policy to use when SOA is called by a head end system  | oracle/http_basic_auth_over_ssl_service_policy  |
Sensus SOA TestHarness Partition Name  | Sensus_Test  | |
Sensus SOA Partition Name  | Sensus  | |
MR Server Endpoint URI  | ||
CD Server Endpoint URI  | ||
OD Server Endpoint URI  | ||
Headend Http Read Timeout  | 500000  | |
Headend Http Connection Timeout  | 50000  | |
SSN SOA Partition Name  | SSN  | |
SOA Weblogic User Name  | ||
SSN SOA Queue JNDI Name  | queue/SSNODRQ  | |
SSN Headend DataAggregation Endpoint URI  | ||
The URL for the SSN 4.7 DataAggregation service (DataAggregation.asmx)  | http://127.0.0.1/CoreServices/DataAggregation.asmx  | |
The URL for the SSN 4.10 DataAggregation service  | https://ssn.ssnsgs.net:3000/amm/webservice/v2_1/DataAggregat...  | |
The URL for the SSN 4.14 DataAggregation service  | https://ssn.ssnsgs.net:3000/amm/webservice/v2_5_1/DataAggregationPort  | |
URL for the SSN 5.1/2.7 DataAggregation service  | https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/DataAggregationPort  | |
URL for the SSN 5.1/2.8DataAggregation service  | https://ssn.ssnsgs.net:3000/amm/webservice/v2_8/DataAggregationPort  | |
SSN Headend DeviceManager Endpoint URI  | ||
URL for the SSN 4.7 DeviceManager service (DeviceManager.asmx)  | http://127.0.0.1/CoreServices/DeviceManager.asmx  | |
URL for the SSN 4.10 DeviceManager service  | https://ssn.ssnsgs.net:3000/amm/webservice/v2_1/DeviceManage...  | |
URL for the SSN 5.1/2.7  DeviceManager service  | https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/DeviceManagerPort  | |
URL for the SSN 5.1/2.8 DeviceManager service  | https://ssn.ssnsgs.net:3000/amm/ webservice/v2_8/DeviceManagerPort  | |
SSN Headend DeviceResults Endpoint URI  | http://127.0.0.1/CoreServices/ DeviceResults.asmx  | |
URL for the SSN 4.7 DeviceResults service (DeviceResults.asmx)  | https://ssn.ssnsgs.net:3000/amm/webservice/v2_1/DeviceResult...  | |
The URL for the SSN 4.10 DeviceResults service  | https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/DeviceResults  | |
The URL for the SSN 5.1/2.7 DeviceResults service  | https://ssn.ssnsgs.net:3000/amm/ webservice/v2_7/DeviceResults  | |
The URL for the SSN 5.1/2.8 DeviceResults service  | https://ssn.ssnsgs.net:3000/amm/ webservice/v2_8/DeviceResults  | |
SSN Headend JobManager Endpoint URI  | ||
The URL for the SSN 4.7 JobManager service (JobManager.asmx)  | http://127.0.0.1/CoreServices/JobManager.asmx  | |
The URL for the SSN 4.10 JobManager service  | https://ssn.ssnsgs.net:3000/amm/webservice/v2_1/JobManagerPort  | |
The URL for the SSN 5.1/2.7 JobManager service  | https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/JobManagerPort  | |
The URL for the SSN 5.1/2.8 JobManager service  | ||
SSN Bridge Destination Name  | SSNTestHarnessBridgeDestination  | |
SSN Bridge Destination Additional Classpath  | ||
SSN Bridge Destination Connection URL  | ||
SSN Bridge Destination Initial Context Factory  | weblogic.jndi.WLInitialContextFactory  | |
SSN Bridge Connection Factory JNDI Name  | jms/SSNTestHarnessConnectionFactory  | |
SSN Bridge Destination Queue JNDI Name  | queue/SSNTestSSNODRQ  | |
SSN Destination Bridge Username  |
DG SOA Partition Name  | DG  | |
DG SOA TestHarness Partition Name  | DG_Test  |
Itron SOA Partition Name  | Itron  | |
DataSubscriberService Output Path  | ||
ExceptionSubscriberService Output Path  | ||
Itron Headend DataService Endpoint URI  | ||
Itron Headend DiagnosticService Endpoint URI  | ||
Itron Headend UtilService Endpoint URI  | ||
Itron Headend ControlService Endpoint URI  | ||
Itron Headend ProvisioningService Endpoint URI  | ||
Itron Headend ProvisioningService370 Endpoint URI  | ||
Itron Headend ControlService370 Endpoint URI:  | ||
Itron SOA TestHarness Partition Name  | Itron_Test  | |
Menu Option  | Name Used in Documentation  | Customer Value Install  |
OUAF DBMS Scheduler User  | OUAF_DBMS_SCHEDULER_USER  | |
WebLogic ThreadPoolWorker Enabled  | WLS_THEADPOOLWORKERENABLED  | |
Online JVM Batch Server Enabled  | BATCHENABLED  | |
Online JVM Batch Number of Threads  | BATCHTHREADS  | |
Online JVM Batch Scheduler Daemon Enabled  | BATCHDAEMON  | |
Enable Batch Edit Functionality  | BATCHEDIT_ENABLED  | |
Batch Online Log Directory  | BATCH_ONLINE_LOG_DIR  | |
JDBC Read Timeout  | JDBC_TIMEOUT  | |
Enable JMS Global Flush for Batch  | ENABLE_JMS_GLOBAL_FLUSH  | |
Add UsernameToken.xml  | ADD_USERNAMETOKEN_XML  | |
IWS deployment target  | WLS_CLUSTER_NAME  | |
Web Admin Server Host  | WEB_ADMIN_SERVER  | |
Split File Size in MB  | TEMPSTORAGE_SPLITFILESIZE  | |
GIS Service Running on the same Web Server  | GIS  | |
GIS Service URL  | GIS_URL  | |
GIS WebLogic System User ID  | GIS_WLSYSUSER  | |
GIS WebLogic System Password  | GIS_WLSYSPASS  | |
Online Display Software Home  | ONLINE_DISPLAY_HOME  | |
Max Queries To Hold In Cache Across All Threads  | XQUERIES_TO_CACHE  | |
Seconds Timeout Flush Cache Completely   | XQUERY_CACHE_FLUSH_TIMEOUT  | |
Malware Scan Host  | MALWARE_SCAN_HOST  | |
Malware Scan Port  | MALWARE_SCAN_PORT  | |
Malware Scan Timeout (Seconds)  | MALWARE_SCAN_TIMEOUT  |
Global JVM Arguments  | GLOBAL_JVMARGS  | |
Ant Min Heap Size  | ANT_OPT_MIN  | |
Ant Max Heap Size  | ANT_OPT_MAX  | |
Ant Additional Options  | ANT_ADDITIONAL_OPT  | |
Thread Pool Worker Java Min Heap Size  | BATCH_MEMORY_OPT_MIN  | |
Thread Pool Worker Java Max Heap Size  | BATCH_MEMORY_OPT_MAX  | |
Thread Pool Worker Additional Options  | BATCH_MEMORY_ ADDITIONAL_OPT  |
HTTP Allowed Methods  | HTTP_ALLOWED_METHODS  | |
Web Application Cache Settings  | WEB_L2_CACHE_MODE  | |
Web Server Port Number  | WEB_WLPORT  | |
CSRF Protection For REST Services  | CSRF_PROTECTION  | |
OWSM Protection For REST Services  | OWSM_PROTECTION_FOR_REST_SERVICES  | |
Domain Home Location  | WLS_DOMAIN_HOME  | |
Batch Cluster URL  | WEB_BATCH_CLUSTER_URL  | |
Strip HTML Comments   | STRIP_HTML_COMMENTS  | |
Authentication Login Page Type  | WEB_WLAUTHMETHOD  | |
Web Form Login Page  | WEB_FORM_LOGIN_PAGE  | |
Web Form Login Error Page  | WEB_FORM_LOGIN_ERROR_ PAGE  | |
Javadocs Login Page  | WEB_JAVADOCS_FORM_LOGIN_PAGE  | |
Javadocs Form Login Error Page  | WEB_JAVADOCS_FORM_LOGIN_ERROR_PAGE  | |
Web Security Role  | WEB_ROLE_NAME  | |
Web Principal Name  | WEB_PRINCIPAL_NAME  | |
Javadocs Security Role  | WEB_JAVADOCS_ROLE_NAME  | |
Javadocs Principal Name  | WEB_JAVADOCS_PRINCIPAL_NAME  | |
Use development Configuration  | WEB_ISDEVELOPMENT  | |
Preload All Pages on Startup  | WEB_PRELOADALL  | |
Maximum Age of a Cache Entry for Text  | WEB_MAXAGE  | |
Maximum Age of a Cache Entry for Images  | WEB_MAXAGEI  | |
JSP Recompile Interval (s)  | WEB_ WLPAGECHECKSECONDS  | |
Enable Strict Transport Security  | ||
Strict Transport Security Max Age  | HSTS_MAX_AGE  | |
Strict Transport Security Include Subdomains  | HSTS_SUBDOMAINS  | |
Strict Transport Security Preload  | HSTS_PRELOAD  | |
Oracle Guided Learning Id  | ORACLE_GUIDED_LEARNING_ID  |
Diagnostic Context Enabled  | WLS_DIAGNOSTIC_CONTEXT_ENABLED  |
Enable CORS For Embedded UI  | ENABLE_CORS  | |
Allowed Frame Ancestors Max Number  | CORS_ALLOWED_FRAME_ANCESTORS_MAX_NUMBER  | |
URI For Variable CSP_FRAME_ANS_HOST1  | CORS_CSP_FRAME_ANS_ HOST1  | |
URI For Variable CSP_FRAME_ANS_HOST2  | CORS_CSP_FRAME_ANS_ HOST2  | |
Custom URL For CSP img-src  | CSP_URL_IMG_SRC  | |
Custom URL For CSP script-src  | CSP_URL_SCRIPT_SRC  | |
Custom URL For CSP style-src  | CSP_STYLE_SRC  | |
Custom URL For CSP font-src  | CSP_FONT_SRC  | |
Custom URL For CSP connect-src  | CSP_CONNECT_SRC  | |
Custom URL For CSP frame-src  | CSP_URL_FRAME_SRC  | |
Custom URL For CSP form-action  | CSP_FORM_ACTION_SRC  | |
URI For Variable FA_DOMAIN  | CORS_FA_DOMAIN  | |
URI For Variable ALM_DOMAIN  | CORS_ALM_DOMAIN  | |
Restriction URLs Enable  | CLOUD_RESTRICTION_URLS_ENABLE  | |
Custom SQL Security  | CUSTOM_SQL_SECURITY  | |
White List Full Path  | CLOUD_WHITE_LIST_PATH  | |
Custom White List Full Path  | CLOUD_CUSTOM_WHITE_LIST_PATH  | |
Substitution Variable List File Location  | CLOUD_SUBSTITUTION_VARIABLE_LIST_FILE_LOCATION  | |
Directory For Variable F1_CMA_FILES  | CLOUD_LOCATION_F1_MIGR_ASSISTANT_FILES  | |
URI For Variable F1_OAUTH2_URI  | CLOUD_LOCATION_F1_OAUTH2_URI  | |
URI for Variable F1_BASE_REST_URL  | CLOUD_LOCATION_F1_BASE_REST_URL  | |
URI for Variable F1_OPEN_API_BASE_URL  | CLOUD_LOCATION_F1_OPEN_API_BASE_URL  | |
URI For Variable F1_BASE_WEB_URI  | CLOUD_LOCATION_F1_BASE_WEB_URI  | |
URI For Variable F1_BASE_IWS_URI  | CLOUD_LOCATION_F1_BASE_IWS_URI  | |
Consolidated Logfile Full Path  | CONSOLIDATED_LOG_FILE_ PATH  | |
Temporary File Location  | TMP_FILE_LOCATION  |
Enable/Disable REST Service For The JMX  | JMX_REST_SERVICE_FLAG  | |
Hostname To Run The REST Server  | JMX_REST_SERVICE_HOST  | |
Batch Port For REST Server  | JMX_REST_PORT_BATCH  | |
Web Port For REST Server  | JMX_REST_PORT_WEB  | |
Business Server Port For REST Server  | JMX_REST_PORT_SERVICE  | |
Server Context  | JMX_REST_CONTEXT  | |
SSL Flag  | JMX_HTTPSSL_FLAG  | |
Keystore File Path  | JMX_HTTPSSL_KEYSTORE_ FILE  | |
Keystore Type  | JMX_HTTPSSL_KEYSTORE_ TYPE  | |
Keystore Passphrase  | JMX_HTTPSSL_KEYSTORE_ PASSPHRASE  | |
Keypair Passphrase  | JMX_HTTPSSL_KEYPAIR_ PASSPHRASE  | |
Trust Store File Path  | JMX_HTTPSSL_TRUSTSTORE_ FILE  | |
Truststore Type  | JMX_HTTPSSL_TRUSTSTORE_ TYPE  | |
Truststore Passphrase  | JMX_HTTPSSL_TRUSTSTORE_ PASSPHRASE  | |
Http Server Username For Authentication  | JMX_HTTP_REST_USERNAME  | |
Http Server Password For Authentication  | JMX_HTTP_REST_PASSWORD  |
enable multispeak30 protocol  | ENABLE_MULTISPEAK30  | |
enable multispeak41 protocol  | ENABLE_MULTISPEAK41  | |
enable cim12 protocol  | ENABLE_CIM12  | |
enable cim20 protocol  | ENABLE_CIM20  |
Enable OSB SSL Port  | false  | |
OSB Trust Keystore Type  | Demo  | |
OSB Trust Keystore File Type  | JKS  | |
OSB Trust Keystore File  |
SOA Initial Heap Size  | 1024  | |
SOA Maximum Heap Size  | 2048  | |
SOA Minimum Perm Size  | 512  | |
SOA Maximum Perm Size  | 1024  | |
SOA Application Additional Options  | ||
The name of the OWSM policy to use when SOA calls another SOA service  | oracle/http_basic_auth_over_ssl_client_ policy  | |
The name of the OWSM policy to use when SOA is called by another SOA service  | oracle/http_basic_auth_over_ssl_service_ policy  | |
The name of the OWSM policy to use when SOA calls an OUAF service  | oracle/wss_http_token_over_ssl_client_ policy  |
OSB Initial Heap Size  | 512  | |
OSB Maximum Heap Size  | 1024  | |
OSB Minimum Perm Size  | 512  | |
OSB Maximum Perm Size  | 1024  | |
OSB Application Additional Options  |
Enable Data Migration  | FALSE  | |
Data Migration Database User  | ||
Data Migration Database Password  |
Enable SOA SSL Port  | false  | |
SOA Trust Keystore Type  | Demo  | |
SOA Trust Keystore File Type  | JKS  | |
SOA Trust Keystore File  |
SSN TestHarness SOA Host Server  | slc11cds.us.oracle.com  | |
SSN TestHarness SOA Port Number  | 8920  | |
SSN SOA TestHarness Partition Name  | SSN_Test  | |
SSN SOA TestHarness Queue JNDI Name  | queue/SSNTestSSNODRQ  |
