Oracle Utilities Market Settlements Management Installation and Configuration Worksheets
During the installation and configuration of the application you will need to provide a variety of system values. These worksheets will assist you in providing that information. They should be completed before installing the application framework. No Customer Install Value fields should be left blank.
Note: The OSB configuration and SOA configuration menus are optional for Oracle Utilities Meter Data Management and Oracle Utilities Customer to Meter, and can be skipped. These configurations are required in case another product such as Oracle Utilities Smart Grid Gateway will also be installed on top of Oracle Utilities Meter Data Management.
WebLogic OSB Configuration
The WebLogic OSB configuration includes:
Menu Option
Name Used In Documentation
OSB Home
OSB_HOME
OSB Host Server
OSB_HOST
OSB Port Number:
OSB_PORT_NUMBER
OSB SSL Port Number
OSB_SSL_PORT
OSB Managed Server Port Number
OSB_MS_PORT_NUMBER
OSB Managed Server SSL Port Number
OSB_MS_SSL_PORT_NUMBER
JDBC URL for database
DBURL_OSB
OSB Service Table Schema Name
RCUSTBSCHEMA_OSB
OSB Service Table Schema Password
RCUSTBSCHEMAPWD_OSB
OSB WebLogic User Name
WEBLOGIC_USERNAME_OSB
OSB WebLogic User Password
WEBLOGIC_PASSWORD_OSB
Mount Point for OSB files
OSB_LOG_DIR
WebLogic SOA Configuration
The WebLogic SOA Configuration includes:
Menu Option
Name Used in this Documentation
SOA Home
SOA_HOME
SOA Host Server
SOA_HOST
SOA Port Number:
SOA_PORT_NUMBER
SOA SSL Port Number
SOA_SSL_PORT_NUMBER
SOA Internal URL
SOA_INTERNAL_URL
SOA External URL
SOA_EXTERNAL_URL
DBURL_SOA
SOA Service table schema Name
RCUSTBSCHEMA_SOA
SOA Service table schema Password
RCUSTBSCHEMAPWD_SOA
SOA WebLogic User Name
WEBLOGIC_USERNAME_SOA
SOA WebLogic User Password
WEBLOGIC_PASSWORD_SOA
Specify the path for XAI/IWS Service
WEB_SERVICE_PATH
WebLogic SOA Configuration Plan
The WebLogic SOA Configuration Plan includes:
Menu Option
MDF Bulk Request Callback URL
D1_BULK_REQUEST_
CALLBACK_URL
MDF Headend http connection timeout
D1_HEADEND_HTTP_CONN_
TIMEOUT
MDF Headend http read timeout
D1_HEADEND_HTTP_READ_
TIMEOUT
MDF SOA Request Queue JNDI Name
SOA_REQUEST_QUEUE_D1
MDF SOA Notify Queue JNDI Name
SOA_NOTIFY_QUEUE_D1
MDF SOA Command Queue JNDI Name
SOA_COMMAND_QUEUE_D1
SGG-NMS TestHarness Partition Name
SOA_PARTITION_D1
Configuration for DataRaker Integration
The Configuration for DataRaker Integration includes:
Menu Option
Destination Queue to publish SGG payloads for DataRaker Integration Tool
SGG_DR_INT_QUEUE
Number of records (SGG Payloads) to accumulate
SOA_DR_PUBLISH_SIZE
Max file size for the accumulated (SGG Payloads) file in Kilobytes
SOA_DR_FILE_SIZE
Specify a time which, when exceeded, causes a new outgoing file to be created in seconds
SOA_DR_ELAPSED_TIME
Polling frequency of Staging directory for new files in seconds
SOA_DR_POLLING_FREQ
Mount point/directory for the accumulated SGG payload file
SOA_DR_STAGING_DIR
Mount Point/directory for the converted XML file to place for DataRaker
SOA_DR_INTEGRATION_DIR
Advanced Menu Options
The advanced menu options are not available during installation. These options can be accessed after installation using the following commands:
Unix
$SPLEBASE/bin/configureEnv.sh -a
Windows
%SPLEBASE%\bin\configureEnv.cmd -a
Advanced Configurations for OSB
The advanced configurations for OSN include:
Menu Option
Enable OSB SSL Port
OSB_SSL
OSB Trust Keystore Type
OSB_TRUST_KS
OSB Trust Keystore File Type
OSB_TRUST_KS_TYPE
OSB_TRUST_KS_FILE
Advanced Memory Configurations for SOA
The advanced memory configurations for SOA include:
Menu Option
SOA Initial Heap Size
SOA_MEMORY_OPT_MIN
SOA Maximum Heap Size
SOA_MEMORY_OPT_MAX
SOA Minimum Perm Size
SOA_MEMORY_OPT_MINPERMSIZE
SOA Maximum Perm Size
SOA_MEMORY_OPT_
MAXPERM SIZE
SOA Application Additional Options
SOA_JVM_ADDITIONAL_OPT
The name of the OWSM policy to use when SOA calls another SOA service
SOA_SOA_CLIENT_POLICY
The name of the OWSM policy to use when SOA is called by another SOA service
SOA_SOA_SERVICE_POLICY
The name of the OWSM policy to use when SOA calls an OUAF service
The advanced memory configurations for OSB include:
Menu Option
OSB Initial Heap Size
OSB_MEMORY_OPT_MIN
OSB Maximum Heap Size
OSB_MEMORY_OPT_MAX
OSB Minimum Perm Size
OSB_MEMORY_OPT_MINPERMSIZE
OSB Maximum Perm Size
OSB_MEMORY_OPT_MAXPERMSIZE
OSB Application Additional Options
OSB_JVM_ADDITIONAL_OPT
The data migration options include:
Menu Option
Enable Data Migration
DATA_MIGRATION
Data Migration Database User
DATA_MIGRATION_DB_USER
Data Migration Database Password
DATA_MIGRATION_DB_PASS
The advanced configurations for SOA include:
Menu Option
Enable SOA SSL Port
SOA_SSL
SOA Trust Keystore Type
SOA_TRUST_KS
SOA Trust Keystore File Type
SOA_TRUST_KS_
TYPE
SOA_TRUST_KS_
FILE
The SSN SOA TestHarness configurations include:
Menu Option
SSN TestHarness SOA Host Server
SOA_HOST_TEST_D7
SSN TestHarness SOA Port Number
SOA_PORT_NUMBER_D7
SSN SOA TestHarness Partition Name
SOA_PARTITION_TEST_D7
SSN SOA TestHarness Queue JNDI Name
SOA_QUEUE_TEST_D7
