Before You Install
Refer to
My Oracle Support for up-to-date additional information on Oracle Utilities Market Settlements Management installation.
Embedded vs Native/Clustered Installation
By default, Oracle Utilities Application Framework uses Oracle WebLogic in embedded mode. This means the Oracle WebLogic installation is essentially pointed to the Oracle Utilities Application Framework product installation and the executables of Oracle WebLogic are only used to execute the code. This has the advantage of being simple and quick to implement with the Oracle Utilities Application Framework generating a simple configuration for Oracle WebLogic to use.
If you want to take advantage of more advanced WebLogic features such as high performance (multiple managed servers) and high availability (clustering) configuration, do not use the embedded install. Rather, use the native/clustered installation which allows you to deploy the Oracle Utilities Application Framework JEE components within Oracle WebLogic, as you would with other JEE applications.
WebLogic Native Installation
With Oracle Utilities Application Framework 25.4, a WebLogic native installation is required. See the
Oracle WebLogic Configuration Guide for Oracle Utilities Framework document on
My Oracle Support for more information.
Application Server Clustering
If you are considering application server clustering, refer to the
My Oracle Support.
For additional information about WebLogic clustering, refer to the
Fusion Middleware Using Clusters for Oracle WebLogic Server documentation.
Directory Names
Directory cannot contain whitespace characters.
Prerequisite Software List
Before you install Oracle Utilities Market Settlements Management, you must install prerequisite software. Refer to the respective installation documentation of the software for instructions on downloading and installing.
Prerequisite Software for Database Server
The prerequisite software for the database component of Oracle Utilities Market Settlements Management is as follows:
• Oracle Database Server 19c: This is required for installing the database component of the Oracle Utilities Market Settlements Management product.
Oracle Database Enterprise Edition version of the database server is supported.
Note: Oracle Database Enterprise Edition and the Partitioning and Advanced Compression options are strongly recommended in all situations.
Prerequisite Software for Application Server
The prerequisite software for the Oracle Utilities Market Settlements Management application component is:
• Oracle Database Client 19.x (Runtime or Administrator client installation type)
• Oracle Java SE Development Kit 17.0.x (Windows and Linux platforms only) 64-bit
• Oracle WebLogic 14.1.2
Web Browser Requirements
The web browsers listed below are supported when used on each of the operating systems indicated:
Using Oracle Utilities Market Settlements Management with Oracle Utilities Customer to Meter
Oracle Utilities Market Settlements Management includes a restricted-use license for Oracle Utilities Customer to Meter. When using this restricted-use license, implementations should install Oracle Utilities Customer to Meter instead of Oracle Utilities Market Settlements Management.
When creating users in this scenario, users should be assigned to the Meter Stack Common Services (Oracle Utilities Market Settlements Management) and Settlement Services (SETT_SERVICES) user groups.
Oracle Utilities Customer to Meter media pack components are available from the
Oracle Software Delivery Cloud. Refer to the
Oracle Utilities Customer to Meter documentation for details regarding installation of Oracle Utilities Customer to Meter.
