Requirements by Tier
The application is deployed on multiple Tiers:
• Tier 1, Desktop
• Tier 2, Web/Business Application Server
• Tier 3, Database Server
Tier 1, Desktop: Software and Hardware Requirements
The client side hardware requirements for Oracle Utilities Market Settlements Management are as follows:.
* or comparable processor
** more RAM may be needed for more graphic intensive application features, such as Oracle Utilities Work and Asset Management’s GIS Viewer or CM Portals that contain numerous graphs.
*** to support browser caching
Note that the hardware requirements above are based on running the application only, and without any additional software running concurrently. If your client setup requires other software running, please adjust the requirements to account for them.
Web Browser Requirements
The web browsers listed below are supported when used on each of the operating systems indicated:
Tier 2, Web/Business Application Server: Software and Hardware Requirements
Refer to the
Supported Platforms section in this chapter to determine which web application servers can be used with the operating system that will be hosting this tier.
The recommendations that follow are based on a standard installation with both the web application and business application servers on the same machine and the system running with the default values. The default values may not support a production environment. You should adjust these values according to your production needs. Refer to the Server Administration Guide on how to change the default values. The minimum resource requirements exclude third-party software installation requirements. Refer to the third- party vendors for specific requirements. The sizing excludes the Oracle database server installation.
Tier 3, Database Server: Software and Hardware Requirements
Refer to the
Supported Platforms section in this chapter for information about supported database servers.
