Configuring Device Event Notification Suppression
Oracle Utilities Meter Data Management includes the following components used when integrating with Oracle Utilities Network Management Systems:
Service Provider Processing Methods
The following processing methods should be associated to the service provider configured for Oracle Utilities Network Management System:
Processing Role
Description
Bulk Response
This role will identify the appropriate message to send with the results of a bulk command execution. For example, this would be used if a large list of devices had been supplied to execute device status check in order to verify outage status.
Response - Success
This role will identify the appropriate message to send for a successful smart meter command
Send Device Event
This role sets up the subscription for device events that Oracle Utilities Network Management System has interest in.
Suppression Notification
This role identifies the appropriate message to send when a notification has been set or removed.
Activity Types
The following processing activity types should be configured:
Activity Type
Description
Bulk Request Header
Configuration for the bulk request header activity type which is used in making smart meter command requests for a list of meters.
Bulk Response
Configuration for the bulk response activity type which organizes the response for bulk requests.
Identifies the device event categories and types that are subject to suppression.
