Configuring Usage Subscription Types
This portal is used to display and maintain a Usage Subscription Type.
You can access the portal by selecting Admin, then Usage, then Usage Subscription Type.
• Usage Subscription Type List: displays all of the Usage Subscription Types so you can choose the one you want to display in more detail
• Usage Subscription Type: shows the specific configuration for the selected Usage Subscription Type
The Usage Subscription Type defines a number of lists for "valid" objects that can be used in conjunction with the overall usage calculation process:
• Valid Usage Recipients
• Valid Service Point Types
• Valid Usage Calculation Groups
• Valid Dynamic Option Types
Parent topic
