Timeliness and Quality Aggregation Processing for Use with Oracle Utilities Analytics Visualization
This topic describes the processes involved in running timeliness and quality aggregation processing for use with  Oracle Utilities Analytics Visualization.
Execute Measurement Quantity Scan
Create an activity of the Measurement Quantity Scanner activity type, and process the activity (by clicking Scan in the Record Action section in the Activity zone).
This process uses the Measurement Quality and Timeliness Dimension Scanner batch control (D1-MQTDS) which creates measuring component aggregators that will also serve as the measuring component dimensions. This process will create a  measuring component aggregator for each unique combination of Postal Code, City, Device Type, Head-End System, Usage Group, Market, Service Type, Geographic Code, Manufacturer/Model, Service Provider (where Market Relationship Type is specified on the dimension scanner activity).
The Measurement Quality and Timeliness Dimension Scanner batch control (D1-MQTDS) supports multi-threading.
This step will create aggregator measuring components for all Valid MC Types to Aggregate defined on the master aggregator type (Measurement Measured Quantity Aggregator).
The created aggregator measuring component's characteristics will contain the Postal Code, City, Device Type, Head-End System, Usage Group, Market, Service Type, Geographic Code, Manufacturer/Model, Service Provider information.
Execute Aggregation
Once the measuring component aggregators have been created, run the Aggregation Monitor (D2-AGG) batch process. This will process ALL active master aggregators (together with the linked sub aggregators) that satisfy the batch filter parameters. Aggregated measurements will be created for the span of the aggregator horizon which is the current date less the horizon days in intervals defined on the master aggregation measuring component type (Measurement Measured Quantity Aggregator).
Condition Top Range and Condition Bottom Range parameters on the Aggregate Measurement Counts and Quantity (D2-AGG-MCQ) algorithm (an Enter algorithm on the Aggregate state of the Measurement Measured Quantity Aggregator (D2-MeasuredQuantityAggregator) business object) define condition ranges for quantity and count aggregation buckets.
This batch process should be run on a scheduled reoccurring basis.
Aggregated Data
Aggregated measurements are created in the Measurement (D1_​MSRMT) and Aggregation Measurement (D1_​AGG_​MSRMT) tables, using the following base package measurement business objects:
Measured Quantity Measurement (D2-MeasuredQuantityMsrmt)
Quality Count Measurement (D2-QualityCountMsrmt)
Timeliness Count Measurement (D2-TimelinessCountMsrmt)
Timeliness Quantity Measurement (D2-TimelinessQuantityMsrmt)
Oracle Utilities Analytics Visualization Fact views access the Aggregation Measurement table.
Oracle Utilities Analytics Visualization Dimension views access the Measuring Component and Measuring Component Characteristics tables.
