Processing and Sending Usage Transactions to External Systems
When Oracle Utilities Meter Data Management is integrated with a customer information system (such as Oracle Utilities Customer Care and Billing), usage transaction information, including bill determinants and other data can be sent to the customer information system (again, such as Oracle Utilities Customer Care and Billing).
Usage transactions are sent to subscribing systems when they enter the "Sent" state. The "Send Usage" (D2-SEND-USG) Enter algorithm on the Sent state of the base package usage transaction business object (D2-UsageTransaction) determines the method used to send the information, based on the Usage Recipient (service provider) defined on the usage transaction's Usage Subscription. Usage transactions can be sent to service providers via either online real-time processing or periodically via batch processing.
Online Real-Time Processing
To set up the service provider to support online real-time notification of usage transactions, do the following:
Create one or more Outbound Message Types that reference the outbound message business object to be used to send usage transaction information to the external system. The base package include the following business object for Usage Transaction Outbound Message (D2-UsageTranOutboundMesg).
Define a Message Sender that will be used to send the message to the external system.
Add the outbound message type to the service provider's External System and reference the Message sender created above.
Add a processing method to the service provider as follows:
Processing Role: Usage Transaction Notification - Online
Processing Method: How To Send US Related Information
Status: Active
Default Processing Method:
Outbound Message Type: the outbound message type created above
Override Processing Method: outbound message types for specific usage subscription types if applicable
Batch Processing
If Oracle Utilities Meter Data Management is integrated with a customer information system (such as Oracle Utilities Customer Care and Billing) that requests bill determinants, usage transaction processing should be coordinated with the requesting system's billing process.
Requests from a billing system that have been indicated as "batch requests" (such as those produced by Oracle Utilities Customer Care and Billing batch billing process) accumulate in a "calculation deferred" state to be processed specially by the Usage Transaction Calculate Defer Monitor batch control (D2-UTCD).
To set up the service provider to support periodic batch processing of usage transactions, use a periodic monitor batch control. These batch programs should invoke the business objects that will contain the usage transaction information. The base package includes the following business object for this: Usage Transaction Outbound Message (D2-UsageTranOutboundMesg).
Next, setup the following configuration:
Processing Role: Usage Transaction Notification - Batch
Status: Active
Batch Control: the batch control created above
Override Processing Method: batch controls for specific usage subscription types if applicable
Errors encountered when processing Usage Transactions can be reprocessed with the following batches:
Reprocessing usage transaction "seeders" in error (D2-UTSED)
Reprocessing usage transactions in error (D2-UTID)
If unexpected errors occur that leave usage transactions in an unmonitored state, the Usage Transaction Monitor batch control (D2-UT), or one based on this batch control with parameter values tailored to any specific requirements, can be used to process those usage transactions.
