Comma Separated Values Format
This page describes the comma separated values format sample implementation.
Sample File Format
In this sample, data is stored as a comma separated values file.
Note: Values in this example cannot contain a literal comma character. This restriction is added for the simplicity of file parser implementation. The parsing logic can be re-implemented to avoid this restriction. It will not affect the rest of functionality.
The sample CSV file contains the following record types:
Interval Usage: Used for interval usage measurements
Device Events: Used for device events
Trail record: Used to provide the read date/time and number of interval usage and device event records in the file
Interval Usage Format
Field Name
Type
Definition
1
Record Type ID
Constant value “U”
Record type identifier
2
Start Date/Time
Time in the Unix Time format.
Meter read’s start date/time
3
End Date/Time
Meter read’s end date/time
4
Device Id
Arbitrary Text
Device identifier
5
Interval Duration
Numeric Integer
The time interval between readings in seconds (seconds per interval).
6
UOM
Arbitrary Text
Describes the units of the data values
7
Data Entry(s)
Numeric Floating-Point and optional Arbitrary Text separated by “:”
Each record can contain unlimited number of data entry fields. Each data entry is a set of two fields – a reading value and an optional reading status flag. Fields are separated by “:” character. The separator is not present when the reading status flag is not provided.
Device Event Format
Field Name
Type
Definition
1
Record Type ID
Constant value “E”
2
Event Date/Time
The date and time at which the event occurred
3
Device Id
Arbitrary Text
Device identifier
4
Event Name
Arbitrary Text
The primary identification name of the event
Trail Record Format
Field Name
Type
Definition
1
Record Type ID
Constant value “T”
2
Creation Date/Time
3
Total Records
Numeric Integer
Displays number of records in file
Sample File
U,1,86400,DEVICE_DG_0,900,KWH,1:S,2.5,-3.99:R,4:B
E,86400,DEVICE_DG_1,Power Outage
U,2,86400,DEVICE_DG_2,900,KWH,1:S,2,3:R,4:B,5,6,7:A
E,86402,DEVICE_DG_3,Tamper attempt suspected
U,3,86400,DEVICE_DG_4,900,KWH,1:S
T,86401,5
Sample Scripts
The sample implementation includes the following sample scripts designed for use with the above CSV format:
DG_​SmplPrCSV: This sample script includes one method in the Library Interface – getParser(). The method returns an instance of the class that implements the com.splwg.d1.domain.sgg.dg.processing.PayloadParser interface. The class contains the following logic:
1. Parses an incoming payload in the CSV Format.
2. Transforms incoming data to Usage or Event related structures based on incoming data type
3. Returns one by one that structures in the Plain XML format
DG_​SmPrCSVCh: This script is provided as a sample to demonstrate how to parse the CSV format in chunks (created via the chunkSize parameter) by utilizing a helper. This sample script includes one method in the Library Interface – getParser(). The method returns an instance of the class that implements the com.splwg.d1.domain.sgg.dg.processing.ChunkProcessor and com.splwg.d1.domain.sgg.dg.processing.GenericPayload interfaces.
The ChunkProcessor interface distinguishes a chunking-aware processor from the rest of implementations. A custom parser implemented in groovy can implement this interface. The GenericPayload interface defines methods needed to get access to a payload via specific helpers. Via this interface, a custom parser gets access to an instance of LineReaderChunked.
If the chunkSize dynamic parameter is not set in an SGG Payload Processing configuration the entire payload will be processed. See Common Parameters for more information about the chunkSize parameter.
1. Reads a line from incoming payload by utilizing the LineReaderChunked.readLineWithinChunk() method
2. Parses a line in the incoming payload (in the CSV Format) that was read in the previous step.
3. Transforms incoming data to Usage or Event related structures based on incoming data type
4. Returns one by one that structures in the Plain XML format
DG_​SmplTrCSV: This sample script includes one method in the Library Interface – getTransformer(). The method returns an instance of class that implements the com.splwg.d1.domain.sgg.dg.processing.PayloadTransformer interface. The class contains the following logic:
1. Transforms incoming message in the Plain XML format into the “native” format (the IMD Seeder or Device Event Seeder XML nodes).
2. Adds new XML nodes as child nodes to the given Result List.
Use the Script portal to view these scripts in more detail.
Parsing
The parser script performs the following data mapping.
Interval Usage to Plain XML Mapping
The following table shows the mapping between fields in incoming interval data and child elements of Payload/Usage element in the Plain XML format:
Interval Usage Field
Plain XML Element
Record Type ID
RecordType
Start Date/Time
StartDateTime
End Date/Time
EndDateTime
Device Id
DeviceId
Interval Duration
IntervalDuration
UOM
UOM
Data Entry(s)
Intervals/
Interval/
Value
[Status]
Record content from incoming file.
RawData
Device Event to Plain XML Mapping
The following table shows the mapping between fields in incoming interval data and child elements of Payload/Event element in the Plain XML format:
Device Event Field
Plain XML Element
Record Type ID
RecordType
Event Date/Time
DateTime
Device Id
DeviceId
Event Name
Name
RawData
XML Schema of Plain XML Format
The Plain XML consists of the Interval Usage and Device Event related elements at the same time.
<xs:schema attributeFormDefault="unqualified"
elementFormDefault="qualified"
targetNamespace="http://xmlns.oracle.com/GenericAdapter"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:ga="http://xmlns.oracle.com/GenericAdapter">
  <xs:element name="Payload" type="ga:PayloadType"/>
  <xs:complexType name="PayloadType">
    <xs:sequence>
      <xs:choice>
        <xs:element name="Usage" type="ga:UsageType"/>
        <xs:element name="Event" type="ga:EventType"/>
      </xs:choice>
      <xs:element name="RawData"  type="ga:NonEmptyString"/>
    </xs:sequence>
  </xs:complexType>
  <xs:complexType name="UsageType">
    <xs:sequence>
      <xs:element name="RecordType" type="ga:RecordTypeUsageType"/>
      <xs:element name="StartDateTime" type="xs:integer"/>
      <xs:element name="EndDateTime" type="xs:integer"/>
      <xs:element name="DeviceId" type="ga:NonEmptyString"/>
      <xs:element name="IntervalDuration" type="xs:integer"/>
      <xs:element name="UOM" type="ga:NonEmptyString"/>
      <xs:element name="Intervals" type="ga:IntervalList"/>
    </xs:sequence>
  </xs:complexType>
  <xs:simpleType name="RecordTypeUsageType">
    <xs:restriction base="xs:string">
      <xs:enumeration value="U"/>
    </xs:restriction>
  </xs:simpleType>
  <xs:complexType name="IntervalList">
    <xs:sequence maxOccurs="unbounded">
      <xs:element name="Interval" type="ga:IntervalType"/>
    </xs:sequence>
  </xs:complexType>
  <xs:complexType name="IntervalType">
    <xs:sequence>
      <xs:element name="Value" type="xs:float"/>
      <xs:element name="Status" type="ga:NonEmptyString" minOccurs="0"/>
    </xs:sequence>
  </xs:complexType>
  <xs:complexType name="EventType">
    <xs:sequence>
      <xs:element name="RecordType" type="ga:RecordTypeEventType"/>
      <xs:element name="DateTime" type="xs:integer"/>
      <xs:element name="Name" type="ga:NonEmptyString"/>
    </xs:sequence>
  </xs:complexType>
  <xs:simpleType name="RecordTypeEventType">
      <xs:enumeration value="E"/>
    </xs:restriction>
  </xs:simpleType>
  <xs:simpleType name="NonEmptyString">
      <xs:minLength value="1"/>
    </xs:restriction>
  </xs:simpleType>
</xs:schema>
Note:Note: A part of incoming file that been used to generate current Plain XML structure will be placed into the Payload/RawData element.
Transformation
The transformer script performs the following mapping.
Plain XML to Seeder XML Mapping
The payload transformer creates the IMD or/and Device Event Seeder XML elements as following:
Usage Mapping: If name of Payload/* node is equal to 'Usage' (interval usage), the script creates an XML element with a name defined in the SGG Payload Processing Configuration field “IMD Seeder BO (Interval)” and the structure according to the following mapping table:
Plain XML Element
IMD Seeder Element
Notes
RecordType
N/A
DeviceId
dvcIdN
UOM
externalUOM
IntervalDuration
spi
StartDateTime
stDt
Convert to OUAF "dateTime" type
EndDateTime
enDt
Intervals/
Interval/
Value [Status]
msrs
Value
msrs/mL/q
Status ->
msrs/mL/sts/stsL/st
N/A
imdType
Const value 'D1IL'
externalId
Value stored in setOrigin method.
serviceProviderExternalId
Value stored in setConfiguration method.
RawData
rawData
If the SGG Payload Processing Configuration has the Populate RAW checkbox checked.
Device Event Mapping: If name of Payload/* node is equal to 'Event' (device event data) create an XML element with a name defined in the SGG Payload Processing Configuration field “Device Event Seeder BO” and the structure according to the following mapping table:
Plain XML Element
Device Event Seeder Element
Note
RecordType
N/A
DateTime
eventDateTime
DeviceId
externalUOM
Name
externalEventName
externalSourceIdentifier
externalSenderId
RawData
rawEventInformation
