Creating Outbound Message Types
Outbound message types must be configured for each command you plan to use in your implementation. The base package includes a set of outbound message types that can be used. The tables below lists the outbound message types provided for each Smart Grid Gateway adapter.
Itron OpenWay Outbound Message Types
This table lists the outbound message types used with the Itron OpenWay adapter, along with the business objects used with each.
Command
Outbound Message Type / Business Object
“Result” Outbound Message Type / Business Object
Device Commissioning
Itron - Add Meter Definitions O/B Msg Type (D8-AMDOBM)
Itron - Commissioning Outbound Message (D8-ItronCommissionOutboundMsg)
N/A
Device Decommissioning
Itron - Deregister Meter O/B Msg Type (D8-DREGOBM)
Itron - Decommissioning Outbound Message (D8-ItronDecommissionOutbndMsg)
N/A
Remote Connect
Itron - Reconnect Meter O/B Msg Type (D8-RCNOBM)
Itron - Remote Connect Outbound Message (D8-ItronRemoteConnectOutbndMsg)
Itron - Get Reconnect Meter Result O/B Msg Type (D8-GRCNOBM)
Itron - Get Remote Connect Results Outbound Message (D8-ItronRemoteCntRsltOutMsg)
Remote Disconnect
Itron - Disconnect Meter O/B Msg Type (D8-DISCOMOBM)
Itron - Disconnect Outbound Message (D8-ItronRemoteDisconnectOutMsg)
Iron - Get Disconnect Meter Result O/B Msg Type (D8-GDMROBM)
Itron - Get Disconnect Result Outbound Message (D8-ItronRemoteDcntRsltOutMsg)
On-Demand Read (Scalar)
Itron - Contingency Read O/B Msg Type (D8-CRDOBM)
Itron - Contingency Read Outbound Message (D8-ItronOnDemandReadOutbndMsg)
Itron - Get Contingency Read Results O/B Msg Type (D8-GCRDOBM)
Itron - Get Contingency Read Result Outbound Message (D8-ItronOnDemandReadRsltOBMsg)
On-Demand Read (Interval)
Scheduled Read (Scalar)
Itron - Scheduled Read O/B Msg Type (D8-SROBM)
Itron - Schedule Read Outbound Message (D8-ItronInterrogateByGrpOBMsg)
Itron - Get Scheduled Read Result O/B Msg Type (D8-GSRROBM)
Itron - Get Schedule Read Result Outbound Message (D8-ItronInterrogateByGrpRsltOB)
Scheduled Read (Interval)
Device Status Check
Itron - Ping By Endpoints O/B Msg Type (D8-DSCOBM)
Itron - Device Status Check Outbound Message (D8-ItronDvcStatusChkOutbndMsg)
Itron - Get Ping By Endpoints Result O/B Msg Type (D8-GDSCROBM)
Itron - Get Device Status Check Result Outbound Message (D8-ItronDvcStatusChkRstlOBMsg)
Multi-Device Status Check
Itron - Multi Ping By Endpoints O/B Msg Type (D8-MDSCOBM)
Itron - Multi Device Status Check Outbound Message (D8-ItronDvcStChkMtDvcOutbndMsg)
Itron - Get Multi Ping By Endpoints Result O/B Msg Type (D8-GMDSCOBM)
Itron - Get Multi Device Status Check Result Outbound Message (D8-ItronDvcStChkMtDvcRsltOBMsg)
Load Check
Itron - Detect Load Side Voltage O/B Msg Type (D8-DLSVOBM)
Itron - Detect Load Side Voltage Outbound Message
(D8-ItronDetectLoadSideVolOBMsg)
Itron - Get Detect Load Side Voltage Results O/B Msg Type (D8-GDLSVOBM)
Itron - Get Detect Load Side Voltage Result Outbound Message
(D8-ItronDetLSVoltMtrRsltOutMsg)
Landis+Gyr Outbound Message Types
This table lists the outbound message types used with the Landis+Gyr adapter, along with the business objects used with each.
Command
Add Meter to Inventory (L+G) (D3-AMIOMTYP)
LG - Add Meter To Inventory OB Message (D3-AddMeterToInventoryOBMsg)
Notify Remove Meter (L+G) (D3-MRENOMTYP)
LG - Meter Remove Notification OB Message (D3-MeterRemoveNotifOBMsg)
Meter Retire
Notify Retire Meter (L+G) (D3-MRNOMTYP)
LG - Meter Retire Notification OB Message (D3-MeterRetireNotifOBMsg)
Meter Exchange
Notify Exchange Meter (L+G) (D3-MENOBMTYP)
LG -Meter Exchange Notification OB Message (D3-MeterExchNotificatnOBMsg)
Remote Connect
Initiate Connect Disconnect by Meter Number (L+G) (D3-INCODIOBM)
LG Initiate Connect Disconnect OB Message (D3-InitConnectDisconnectOBMsg)
Remote Disconnect
Demand Reset
Schedule Demand Reset (L+G) (D3-SDROMTYP)
LG - Schedule Demand Reset OB Message (D3-ScheduleDemandResetOBMsg)
On-Demand Read (MultiSpeak)
Initiate Read by Meter Number (L+G) (D3-INMRMNOBM)
L+G MultiSpeak InitiateMeterReadByMeterNumber OB Message (D3-InitMtrReadByMtrNumOBMsg)
On-Demand Read (Interval) [CIM]
Initiate On-Demand Read (CIM L+G) (D3-CIMODR)
CIM AMIRequest GetMeterReads OB Message (D3-CIMAMIRequestGetMtrRdOBMsg)
On-Demand Read (Scalar) [CIM]
Device Status Check
Initiate Device Status Check (CIM L+G) (D3-CIMDSC)
Sensus Outbound Message Types
This table lists the outbound message types used with the Sensus adapter, along with the business objects used with each.
Command
Notify Add Meter (Sensus) (D6-SMANOMTYP)
Sensus - Meter Add Notification OB Message (D6-MeterAddNotificationOBMsg)
Notify Remove Meter (Sensus) (D6-SMRNOMTY)
Sensus -Meter Remove Notification OB Msg (D6-MeterRemoveNotificatnOBMsg)
Remote Connect
Initiate Connect Disconnect by Meter Number (Sensus) (D6-INCODIOBM)
Sensus Initiate Connect Discon OB Message (D6-InitConnectDisconnectOBMsg)
Remote Disconnect
Initiate Read by Meter Id (Sensus) (D6-SIMROMTY)
Sensus - Initiate Meter Read By MtrID OBMsg (D6-InitMtrRdMtrIdOBMsg)
Device Status Check
Initiate Outage Detection (Sensus) (D6-SIODTOMTY)
Sensus InitiateOutageDetection OB Message (D6-InitOutageDetectionOBMsg)
Silver Spring Networks Outbound Message Types
This table lists the outbound message types used with the Silver Spring Networks adapter, along with the business objects used with each.
Command
Replace Location (Commission SSN) (D7-RLOCOBMTY)
SSN - Replace Location (Comm) Outbound Message (D7-ReplaceLocationOBMsg)
N/A
Replace Device (Decommission SSN) (D7-RDVCOBMTY)
SSN - Replace Device At Loc O/B Message (D7-ReplaceDeviceAtLocOBMsg)
N/A
Remote Connect
Connect Disconnect Device (SSN) (D7-CDCOBMTYP)
SSN - Connect Disconnect OB Message (D7-ConnectDisconnectOBMsg)
Get Connect Disconnect Result (SSN) (D7-GCDROBMTY)
SSN - GetConnectDisconnectResult OB Message (D7-GetCntDiscntResultOBMsg)
Remote Disconnect
Add Scalar Read Job (SSN) (D7-AMRJSCOBT)
SSN - Add Meter Read Job Scalar OB Message (D7-AddMeterReadJobScalarOBMsg )
Get Scalar Read Results by Job Id (SSN) (D7-GMRRBJOMT)
SSN - GetMeterReadResults(Scalar) OB Message (D7-GetSclrMtrRdRstByJobIdOBMsg )
Add Interval Read Job (SSN) (D7-AMRJINOBT)
SSN - AddMeterReadJob Interval OB Message (D7-AddMtrReadJobIntervalOBMsg )
Get Interval Read Results by Job Id (SSN) (D7-GIMRRJOMT)
SSN - GetMeterReadResults(Interval) OB Message (D7-GetIntMtrRdRsltByJobIdOBMsg )
Device Status Check
Add Meter Ping Job (SSN) (D7-APJOBM)
SSN - Add Ping Job OB Message
(D7-AddPingJobOBMsg)
Get Device Ping Job Results (SSN) (D7-GPJROM)
SSN - Get Ping Results O/B Message (D7-GetPingResultsOBMsg)
