Business Flag Hold
This rule can be used to place a hold on a usage transaction until the business flags related to the usage transactions service points can be investigated. The hold can be placed in one of two ways:
Calculation Window Based: holds will remain until either a user manually bypasses the usage exception error or the current date is within a configurable tolerance of the calculation window end (aka the retry until date time).
Indefinite: holds require a user to manually bypass the usage exception that is generated.
Defining which business flags should result in a usage transaction is a matter of identifying which business flag types, priorities, and confidences should be included.
Additional detail on the logic of this rule can be found in the Detailed Description of the D2-AUR-IBFH algorithm type.
For help with the meaning of specific configuration fields, refer to the embedded help on the screen when adding or editing the rule.
Business Object
D2-BusinessFlagHold
