Execute Usage Calculation Group
This rule performs a call to execute a separate usage calculation group which includes execution of all usage calculation rules within that group. It is especially useful in cases where repeating the same rule over and over would be hard to maintain.
For example, you may want to calculate a straightforward kWh sum for every usage calculation group. Creating a separate CALC_​KWH_​SUM usage calculation group for this one calculation allows you to isolate the configuration points. Then the CALC_​KWH_​SUM usage calculation group can be referenced in every other usage calculation group that needs this sort of service quantity.
Additional detail on the logic of this rule can be found in the Detailed Description of the D1-AUSGR-RFG Algorithm Type.
For help with the meaning of specific configuration fields, refer to the embedded help on the screen when adding or editing the rule.
Business Object
D1-UsageRuleReferredUsageGroup
