Interval Spike Check
This rule looks for spikes by taking the highest interval and the third-highest interval, and determining the percent difference between the two. If the percent difference is larger than the tolerance configured on the rule, the algorithm logs an exception of the type and severity configured on the rule.
The rule can be executed in one of two modes (as configured on the rule):
The spike check is performed for every 24-hour chunk of data in the initial measurement data set
The spike check is performed for the entire initial measurement data set
Additional detail on the logic of this rule can be found in the Detailed Description of the D2-INTSPKCHK Algorithm Type.
For help with the meaning of specific configuration fields, refer to the embedded help on the screen when adding or editing the rule.
Business Object
D2-IntervalSpikeCheck
