Multiplier Check
This rule validates that the register multiplier supplied with the Initial Measurement is equal to the multiplier stored on the measuring component.
Additional detail on the logic of this rule can be found in the Detailed Description of the D2-REGMULCHK Algorithm Type.
For help with the meaning of specific configuration fields, refer to the embedded help on the screen when adding or editing the rule.
Business Object
D2-RegisterMultiplierCheck
