Unit of Measure Check
This rule checks the unit of measure (UOM) passed in with the Initial Measurement against the primary unit of measure configured on the measuring component's type.
Additional detail on the logic of this rule can be found in the Detailed Description of the D2-UOMCHK Algorithm Type.
For help with the meaning of specific configuration fields, refer to the embedded help on the screen when adding or editing the rule.
Business Object
D2-UOMCheck
Parent topic
