Maintaining Measuring Component Comparison Periods
You use the Measuring Component Comparison Period portal to maintain measuring component comparison periods.
You can access the portal from Menu > Device > Measuring Component Comparison Period. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
Measuring Component Comparison Period: This zone displays the basic attributes of the measuring component comparison period.
