Maintaining Aggregations
This portal is used to display and maintain Aggregations.
You can access the portal from the Main > Totals and Trends > Consumption Statistics. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
Measuring Component: defines the basic attributes of the aggregator measuring component.
Measuring Component Attributes: displays attributes that describe the dimensions and criteria for the aggregation measuring component (applies to dynamic aggregation measuring components only)
Measurements — Interval: displays aggregated measurement data for the selected aggregator measuring component.
Interval - Audit View: allows users to view an interval measurement curve for a given period overlaid with the count of audit records for each individual measurement.
Final Values Overlay: displays final measurements for a measuring component, and provides the ability to overlay the graphed data with final measurements from other measuring components.
Time of Use Overlay: displays an overlay of the TOU periods on a final interval measurement along with totalized TOU consumption based on a user-defined time period and TOU map
Related Measuring Component Sets: lists measuring components sets of which the aggregator measuring component is a member (applies to dynamic aggregation measuring components only)
Usage Subscriptions Directly Linked to MC: lists usage subscriptions that are directly linked to current measuring component
