Maintaining Device Configurations
You use the Device Configuration portal to maintain device configurations.
You can access the portal from Menu > Device > Device Configuration. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
This portal includes the following zones:
Device Configuration: Defines the basic attributes of the device configuration
Measuring Components: Lists the measuring components for the device configuration
Scalar Readings: Displays a list of scalar readings for scalar measuring components associated with the current device configuration. To create a new reading for scalar measuring components associated with the device configuration, click New Reading. To edit an existing reading, click the edit icon for the reading you wish to edit.
NOTE: The Scalar Readings zone is available only with Oracle Utilities Meter Data Management.
