Maintaining Install Events
This portal is used to display and maintain an Install Event.
You can access the portal from Menu > Device Installation > Install Event. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
Install Event: defines the basic attributes of the Install Event, the on/off history for the Install Event, and removal information.
When creating a new record, the following options are available:
Name
Details
Business Object
Communication Component Install Event
This Install Event is intended for use with a Communication Component that is installed on top of a traditional Meter.
D1-CommComponentInstallEvent
Item Installation Event
This Install Event records the installation of an Item (i.e. streetlight).
D1-ItemInstallEvent
Manual Meter Installation Event
This Install Event is used for manually read meters.
D1-ManualMeterInstallEvent
Smart Meter Installation Event
This Install Event is unique to smart meters and has a lifecycle that's maintained by remote meter commands.
D1-SmartMeterInstallEvent
