Maintaining Initial Measurement Snapshots
You use the Initial Measurement Snapshot portal to view and maintain initial measurement snapshots.
You can access the portal by selecting Menu, then Initial Measurement Snapshot. You are brought to a query portal with options for searching. You can search by:
Initial Measurement Snapshot From
Initial Measurement Snapshot To
Show Initial Measurement Snapshot in Error
Initial Measurement Snapshot: This zone displays the selected initial measurement snapshot.
