Maintaining Settlement Billed Usage
You use the portal Settlement Billed Usage portal to view and maintain settlement billed usage.
You can access the portal from the Main > Settlement > Settlement Billed Usage. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
Settlement Billed Usage: This zone displays basic information about the settlement billed usage, including billed usage periods.
