Maintaining Attribute Values
You use the Attribute Value portal to view and maintain attribute values records.
You can access the portal by selecting Main, then Customer Information, then Attribute Values. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
Attribute Values: This zone displays the attribute values record.
