Maintaining Usage Subscription Quantities
You use the Usage Subscription Quantity portal to view and maintain usage subscription quantities.
You can access the portal by selecting Main, then Usage, then Usage Subscription Quantity. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
Usage Subscription Quantity: This zone displays the basic attributes of the usage subscription quantity
