Using 360 Degree Search
The 360 Degree Search feature allows users to search for devices, measuring components, service points, and/or usage subscriptions using a variety of search criteria.
From the search results list, you can navigate to the 360 Degree View portal to view data on one of the following tabs:
Measuring Component
Device
Service point
Usage Subscription
Contact
When accessed, the 360 Degree View opens on the tab corresponding to the type of object (device, measuring component, etc.) you select. For example, if you click the Measuring Component description, the Measuring Component tab opens.
The following options are available for 360 Degree Search:
Search by Name: Allows search by name/address OR contact identifier OR usage subscription identifier. To search by address, click Go To Search by Address. To search by device, click Device.
Search by Address: Allows search by address/name OR service point identifier. To search by name, click Go To Search by Name. To search by device, click Device.
Note: "Search by Address" search results contain service points with one or more active usage subscriptions only.
Search by Device: Allows search by device identifier OR measuring component identifier. To search by name, click Go To Search by Name. To search by address, click Address.
