Non-Interval 'Plain' XML to IMD Mapping
The following table outlines how non-interval data in the "plain" XML format is mapped to the InitialLoadIMD format when the Landis+Gyr record type is set to "EMED01" (non-interval usage).
"Plain" XML Element
InitialLoadIMD element
Notes
RecordType
N/A
Premise
N/A
ESIID
N/A
Provisioned
N/A
MeterID
dvcIdN
as is
kWh
enQty
as is
uom
KWH
TimeStamp
enDt
Convert to OUAF date/time format
This should be mapped to enDt. Relevant only to non-interval data.
Peak
enQty
as is
A separate IMD Seeder will be created with <uom> in IMD Seeder populated with KW
PeakDateTime
enDt
Dmd
enQty
as is
A separate IMD Seeder will be created with <uom> in IMD Seeder populated with KW and 'Dmd' in "<mcIdN>
TouA
enQty
as is
A separate IMD Seeder will be created with <uom> in IMD Seeder populated with KWH and 'kWh Rate A' in "<mcIdN>
TouB
enQty
as is
A separate IMD Seeder will be created with <uom> in IMD Seeder populated with KWH' and 'kWh Rate B' in "<mcIdN>
TouC
enQty
as is
A separate IMD Seeder will be created with <uom> in IMD Seeder populated with KWH and 'kWh Rate C' in "<mcIdN>
TouD
enQty
as is
A separate IMD Seeder will be created with <uom> in IMD Seeder populated with KWH and 'kWh Rate D' in "<mcIdN>
TouE
enQty
as is
A separate IMD Seeder will be created with <uom> in IMD Seeder populated with KWH and 'kWh Rate E' in "<mcIdN>
Volts
enQty
as is
A separate IMD Seeder will be created with <uom> in IMD Seeder populated with Volts
PF
enQty
as is
A separate IMD Seeder will be created with <uom> in IMD Seeder populated with PF
N/A
imdType
D1IL
Origin
externalId
the origin element in "Plain" XML (incoming file name)
N/A
serviceProviderExternalId
L+G
This is a constant. There is no such field in incoming structure.
RawData
rawData
Vendor-specific "raw" data
When the "populateRawIMD" parameters in the EnvironmentSettings.xq file is set to true.
