Communication Flows
The table below lists the communications created for each NES command:
Command
Outbound Communication
Inbound Communication
Completion Event
Remote Connect
Retrieve Meter Information
Read Load Status
Read Billing Data On-Demand
Connect Load
Read Load Status Notification
Read Billing Data On-Demand Notification
Connect Load Notification
Create IMD
Connect Device
Remote Disconnect
Disconnect Load
Disconnect Load Notification
Create IMD
Disconnect Device
Device Commissioning
Add Meter Request
Set ATM Configuration
Set ATM Configuration Notification
Device Decommissioning
Decommission Meter Request
Decommission Meter Notification
On-Demand Read
(Scalar)
Create IMD
On-Demand Read
(Interval)
Read Load Profile On Demand
Read Load Profile On-Demand Notification
Create IMD
Commissioning and Decommissioning Communications
Commissioning a previously decommissioned NES device requires a different process than commissioning a new device.
When you commission a device for the first time, a commissioning command is sent to BPEL to create the meter in NES using the DeviceManager.CreateMeter command. If Automatic Topology Management is selected then the DeviceManager.SetATMConfiguration command is also sent.
When you decommission a device, BPEL sends the DeviceManager.Move command to NES for the device. In NES you need to confirm that the device has been moved to a non-DC tree. You then need to manually delete the device from the non-DC tree. To permanently decommission the device you must delete it by using the DeviceManager.Delete command from the NES interface.
To recommission a device that has been previously decommissioned, you need to log into NES and manually move the meter from the non-DC tree to the DC tree that it belonged to previously. This will not be possible if the device has been deleted from within NES.
