Outbound Message Types
Outbound message types define specific types of messages sent to an external system, such as messages containing device command requests.
The following outbound message types must be configured in your system. If these are not present in your configuration, add them. Refer to the Oracle Utilities Application Framework documentation for more information about creating outbound message types.
Outbound Message Type | Description |
D8-CONREAD | Itron Contingency Read By Endpoints |
D8-INTRGRP | Itron Interrogate By Group |
D8-COMM | Itron Commission |
D8-DCOMM | Itron Decommission |
D8-DSC | Itron Device Status Check |
D8-DSCMD | Itron Device Status Check Multi Device |
D8-DLSV | Itron Detect Load Side Voltage |
D8-RCONN | Itron Remote Connect |
D8-RDCONN | Itron Remote Disconnect |
D8-RDSS | Itron Read Disconnect State |
Note: The following apply to all of the above outbound message types:
• Business Object: D1-OutboundMessage (Outbound Message)
• Priority: Priority 50
Parent topic
