Device Communication Base Package Business Objects
The Itron OpenWay Adapter base package includes the following communication business objects:
Business Object Name
Description
D8-AddMeterDefinitions
 Itron - Add Meter Definition (Commission)
D8-DeregisterMeter
 Itron - Deregister Meter (Decommission)
D8-DetectLoadSideVoltageByMtr
 Itron - Detect Load Side Voltage
D8-DetLoadSideVoltageMtrRslt
 Itron - Detect Load Side Voltage Result
D8-DisconnectMeter
 Itron - Disconnect Meter (Remote Disconnect)
D8-DisconnectMeterResult
 Itron - Disconnect Meter Result
D8-PingByEndpoints
 Itron - Ping By Endpoints (Device Status Check)
D8-PingByEndpointsMDResponse
 Itron - Multi-Device Ping Response
D8-PingByEndpointsMultiDevice
 Itron - Ping By Endpoints Multi-Device
D8-PingByEndpointsResponse
 Itron - Ping By Endpoints Response
D8-ReadDisconStateByMtr
 Itron - Read Disconnect State
D8-ReadDisconStateMtrRslt
Itron - Read Disconnect State Result
D8-ReadInterval
 Itron - Contingency Read (Interval)
D8-ReadResult
 Itron - Contingency Read Result
D8-ReadScalar
 Itron - Contingency Read (Scalar)
D8-ReconnectMeter
 Itron - Reconnect Meter (Remote Connect)
D8-ReconnectMeterResult
 Itron - Reconnect Meter Result
Itron OpenWay Event Data Mapping
The Itron OpenWay event file format maps as follows into the business object, D1-DeviceEventMappingLookup:
Itron OpenWay Flat File Field
Device Event Seeder BO Element
Comments
Transaction ID (from Header record)
External Source Identifier
This is the file name.
Device Identifier
External Device Identifier
Event Name
External Event Name
Event Creation Date/Time
Event Date/Time
Device Type
External Device Type
This element has no real bearing on the device type within MDM/SGG. Its valid values include (although the element itself is free-form):
Meter
Collector
Router
Service Location ID
External Service Location ID
Communication Module Serial Number
External Communication Module Identifier
Event Category ID
External Event Category
Event Severity
External Event Severity
Valid values include (although the element itself is free-form):
Alert
Information
Status Value
External Status Value
This represents additional information that relates to the event itself.
Status Date/Time
External Status Date/Time
The date & time at which the additional information referenced above had occurred.
