Communication Flows
The table below lists the communications created for each Adapter Development Kit command:
Command
Outbound Communication
Inbound Communication
Completion Event
Remote Connect
ADK - Initiate Connect or Disconnect
ADK - Connect/ Disconnect State Change
Connect Device
Create IMD
Remote Disconnect
ADK - Initiate Connect Disconnect
Disconnect Device
Create IMD
Device Commissioning
ADK - Meter Add Notification
Device Decommissioning
ADK - Meter Remove Notification
On-Demand Read (Scalar)
ADK - Initiate Meter Read by Meter ID
ADK - Reading Changed Notification
Create IMD
On-Demand Read (Interval)
Create IMD
Device Status Check
ADK - Initiate Outage Detection
ADK - Outage Detection Event Notif
Unit of Measure Filtering for On-Demand Reads
Readings returned via On-Demand Read commands are filtered on the combination of Unit of Measure/Time of Use/Service Quantity Identifiers (UOM/TOU/SQI) configured for the device and measuring component. When filtering is enabled, only readings that match a configured UOM/TOU/SQI combination are processed. All others are filtered out.
Filtering is enabled by default via the “Opt Out Of Filtering” parameter (set to "false" by default) on the DG-CCOMPEV (Create IMD Completion Event) algorithm on the Create Completion Events status of the DG-ReadingChgNotification (ADK - Reading Changed Notification) business object.
The DG-VALDVCFIL (Check if Device has any Filtering errors) algorithm on the Validate status of the DG-ReadingChgNotification (ADK - Reading Changed Notification) business object is used to check for errors related to filtering. The value of the “Opt Out Of Filtering” parameter on this algorithm must match the value of the parameter on the DG-CCOMPEV algorithm. The parameters should both be set to either "false" (the default) or "true" (if filtering is to be disabled).
