Defining Redaction Rules
This portal is used to view and maintain rules that define how specific fields that containing personal information should be redacted when exported out of the application. For example, an e-mail address may be redacted by replacing some or all characters with ‘*’.
You can access the portal from theAdmin Menu > Security > Redaction Rule. You are brought to a query portal with options for searching for a specific redaction rule. Once a redaction rule has been selected you are brought to the maintenance portal to view and maintain the selected record.
This functionality is for future use.
The following zones may appear as part of the portal's Main tab page
Redaction Rule. This zone provides information about the selected rule.
