Defining Asset Types
You use the Asset Type portal to display and maintain asset types.
You can access the portal by selecting Admin, then Asset Management, then Asset Type. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
Asset Type : This zone provides information about the asset type.
Asset Type Statistics: This zone displays statistics for the asset type.
