Defining Configuration Types
You use the Configuration Type portal to display and maintain configuration types.
You can access the portal by selecting Admin,, then Asset Management, then Configuration Type.
• Configuration Type: This zone lists all configuration type records. Broadcast a record to display the details of the selected record.
• Configuration Type : This zone provides information about the selected configuration type.
Parent topic
