Defining Asset Completion Event Types
You use the Completion Event Type portal to display and maintain asset completion event types.
You can access the portal by selecting Admin, then Asset Management, then Asset Completion Event Type. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
• Completion Event Type : This zone provides information about the selected completion event type, including as inbound communications and attachments.
• Unlink Activity Types: This zone enables the removal of an activity type from the completion event type. To remove an activity type select the activity type(s) to remove and click Remove. The selected activity types will no longer appear in the Unlink Activity Types zone.
• Link Activity Types: This zone enables adding an activity type to the completion event type. To link an activity type:
1. Enter search criteria n the Activity Type Description field and click Search. The zone will display a list of activity types matching your search criteria.
2. Select the activity type(s) to add and click Link. The selected activity types will now appear in the Unlink Activity Types zone.
Parent topic
