Defining Organization Types
You use the Organization Type portal is used to display and maintain organization types.
You can access the portal by selecting Admin, then Location, then Organization Type.
• Organization Type List: This zone lists all organization type records. Broadcast a record to display the details of the selected record.
• Organization Type: This zone provides information about the selected organization type.
Parent topic
