Configuring Extracts
Oracle Utilities Meter Data Management includes the following components used when integrating with Oracle Utilities Analytics:
Master Configuration
The following master configurations are used to configure the sync process between MDM and OUA:
Master Configuration | Description |
Analytics Master Configuration - ODI-Based | This master configuration is primarily used to configure the information that will be used in the extraction of data for business intelligence when using the Oracle Data Integrator extract, transform, and load (ETL) process. |
Batch Controls
Batch Code | Name / Description |
D1-SPSDL | Service Point Snapshot Download |
D2-DUGDL | Usage Subscription Usage Calculation Group Download |
D2-USGDL | Service Point Usage Snapshot Download |
D2-UUSDL | SP Unreported Usage Snapshot Download |
D2-VEEDL | SP VEE Exception Snapshot Download |
Refer to the following documentation for more information about Oracle Utilities Analytics:
Oracle Utilities Extractors and Schema for Oracle Utilities Meter Data Management Data Mapping Guide
Oracle Utilities Analytics Dashboards for Meter Data Analytics Metric Reference Guide
Oracle Utilities Analytics Admin Guide
Parent topic
