Configuring Measurement Cycles
This portal is used to display and maintain a Measurement Cycle.
You can access the portal by selecting Admin, then Device Installation, then Measurement Cycle. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
• Measurement Cycle List: This zone lists all Measurement Cycle records. Broadcast a record to display the details of the selected record.
• Measurement Cycle Type: This zone provides information about the selected Measurement Cycle.
• Measurement Cycle Route List: This zone lists the measurement cycle routes related to the measurement cycle.
• Measurement Cycle Schedule List: This zone lists the measurement cycle schedules related to the current measurement cycle.
Parent topic
