Interval Profile Estimation
This rule uses a profile measuring component's interval consumption as a source of values to assign to intervals in the current Initial Measurement Data set that are marked "missing" via the interval's condition. If the interval is marked with a condition indicating "outage", the algorithm skips it.
If a measurement is not available for the profile measuring component on the date/time, the interval is left unchanged.
Additional detail on the logic of this rule can be found in the Detailed Description of the D2-INTPROEST Algorithm Type.
For help with the meaning of specific configuration fields, refer to the embedded help on the screen when adding or editing the rule.
Business Object
D2-IntervalProfileEstimation
Parent topic
