Activity Type Category | Activities of this type category are used to |
Bulk Activity | Initiate a smart meter command for a group of meters using Oracle Utilities Smart Grid Gateway |
Command Request | Initiate a smart meter command for an individual meter using Oracle Utilities Smart Grid Gateway |
Consumption Sync | Trigger related measuring component estimation synchronization |
Device Event Activity | Represent a device event. These are used when viewing usage and events with the Oracle Utilities Meter Data Management 360 Degree View. |
Dimension Scanner | Trigger dimension scanning when aggregating usage, statistics, and other data. |
Error Activity | Represent errors in activity processing. |
Extract Request | Retrieve usage and device events from a head-end system using Oracle Utilities Smart Grid Gateway |
Field Activity | Initiate field work via a message to an external field work system. Activities of this type are most often created by a request orchestration activity. |
Meter Read Download Activity | Download a list of meters to be read. |
Multi Device Command Request | Initiate a smart meter command for multiple meters (for head-end systems that support multi-device commands) using Oracle Utilities Smart Grid Gateway |
Non-Dispatchable Activity | Represent steps or stages in a larger process in which the system is waiting for a resolution from another system. Examples include "Wait for Measurement" or "Wait for Scheduled Read." |
Orchestration Maintenance | Update or cancel an active service order activity. |
Payload Statistics | Calculate processing statistics for usage and device event import processing |
Request Orchestration | Orchestrate the steps necessary to fulfill a service request, based on the current state of the service point related to the request. |
Suppression | Suppress sending of device events to subscribing systems (such as Oracle Utilities Network Management System) |
Usage Transaction Correction Processor | Trigger correction processing for usage transactions when corrected usage is received that would impact an existing usage transaction |
