Maintaining Network Locations
This portal is used to display and maintain a Network Location.
You can access the portal from Menu > Device Installation > Network Location. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
• Network Location: defines the basic attributes of the network location
• Service Points Related to Network Location: displays a list of Service Points related to the current network location, in reverse chronological order.
Parent topic
