Action  | Allowed Statuses  | Details  |
Approve  | Approval In Progress Issue Detected (only when the exceptions are marked to require approval)  | Allows a user to bypass any exception or failure message for the settlement transaction and attempt to send it to the requesting system.  |
Calculate  | Approval In Progress Pending  | Allows a user to trigger settlement calculations.  |
Discard  | Approval In Progress Export Error Issue Detected  | Allows a user to discard the settlement transaction.  |
Export  | Export Error  | Allows a user to transition the settlement transaction to the Export status and send the settlement transaction to the recipients.  |
Export Manually  | Export Error  | Allows a user to manually export the settlement transaction send it to the recipients.  |
Override Exception  | Issue Detected  | Allows a user to override an exception and transition the settlement transaction to the Override Exception state.  |
Re-Calculate  | Issue Detected  | Reruns the entire process of calculation along with any validations (all settlement calculation rules) for the settlement transaction.  |
Supercede  | Completed  | Allows a user to indicate that the settlement transaction was corrected after being sent. Sets the status of the settlement transaction to Superceded.  |
