Inbound Web Service | Description |
D1-BulkRequestHeader | Bulk Request Header |
D1-BulkRequestUpdate | Bulk Request Update |
D1-BulkResponse | Bulk Response |
D1-DeviceEventSeeder | Used for upload of device events. The Device Event Seeder business object serves as a means of adding device events both from outside the application and from online. Its pre-processing algorithms determine the device event type - which in turn defines the device event BO that should be used to create the device event. If a device event type can't be determined, the device event is created using this BO. Such a device event can then be re-processed - and if successful, a new device event is created. |
D1-InitialLoadIMD | Used for initial measurement upload. The IMDSeeder business object is used to determine the type of initial measurement business object to instantiate when receiving usage readings from a head-end system. |
D3-CIMMeterReadingsResponse | CIM Meter On Demand Read Response Retrieve response from CIM On Demand Read command |
D3-CIMPingResponse | CIM Ping Response Retrieve response from CIM Device Status Check command |
D3-ConDisconStChgNotification | Initiate Connect Disconnect response. Retrieve response from the Initiate Connect Disconnect command. |
D3-ReadingChangedNotification | Reading Changed Notification Notification that a Landis+Gyr device reading has changed. |
D3-ScheduleDemandResetResponse | Scheduled Demand Reset Response Retrieve response from Demand Reset command |
Message Sender | Description |
D3-Comms | Commission Device |
D3-Connect | Connect Device |
D3-Decomm | Decommission Device |
D3-Decomms | Decommissioning Sender |
D3-DemReset | Demand Reset |
D3-DerDevice | Deregister Device |
D3-Disconnec | Disconnect Device |
D3-InitMTR | Initiate Meter Read by Meter Number Outbound Message |
D3-MTREXMS | Meter Exchange Notification Message Sender |
D3-RTSender | Real Time Sender |
D3-RTSnd | Real-time Sender (Landis+Gyr) |
D3-SDemReset | SG Demand Reset |
