Message Senders
Message senders define the details of how messages are sent to an external system, such as messages containing device command requests.
The following message senders must be configured in your system. If these are not present in your configuration, add them. Refer to the Oracle Utilities Application Framework documentation for more information about creating message senders.
Message Sender | Description |
D4-ADDMETREQ | Add Meter Request |
D4-CONLOAD | Connect Load |
D4-DECOMMIS | Device Decommissioning |
D4-DISCONLD | Disconnect Load |
D4-HNLBATEVT | NES Handle Batch Event |
D4-HNLBATUSG | NES Handle Batch Usage |
D4-RDLOADST | Read Load status |
D4-READBILLD | NES On-Demand Read (Scalar)(2) |
D4-READLP | Read Load Profile |
D4-RETMETID | Retrieve Meter Identifier |
D4-RETRIEVE | Retrieve Meter Information |
D4-ReadBill | Read Billing Data |
D4-SETATMCFG | Set ATM Configuration |
Note: The following apply to all of the above message senders:
Main Tab:
• Invocation Type: Real-time
• Message Class: RTHTTPSNDR (Sender routes message via HTTP real-time)
• MSG Encoding: UTF-8 message encoding
Context Tab:
• HTTP Header: SOAPAction: http://xmlns.oracle.com/ouaf/echelon/<OPERATION>
• HTTP Login User: <USER_ID>
• HTTP Login Password: <PASSWORD>
• HTTP Method: POST
• HTTP URL 1: http://<EM_SERVER>:<EM_SERVER_PORT>/soa-infra/services/D4/<SERVICE>/<SERVICE>
where:
◦ <OPERATION>: the operation performed by the message sender (see Operation column in the table above)
◦ <USER_ID>: the user ID used to log into WebLogic Enterprise Manager
◦ <PASSWORD>: the password used to log into WebLogic Enterprise Manager
◦ <EM_SERVER>: the machine name or IP address of server where the WebLogic Enterprise Manager is installed
◦ <EM_SERVER_PORT>: the port where the WebLogic Enterprise Manager is installed
◦ <SERVICE>: the service invoked by the message sender (see Service column in the table above)
Parent topic
