Inbound Web Service | Description |
D1-DeviceEventSeeder | Used for upload of device events. The Device Event Seeder business object serves as a means of adding device events both from outside the application and from online. Its pre-processing algorithms determine the device event type - which in turn defines the device event BO that should be used to create the device event. If a device event type can't be determined, the device event is created using this BO. Such a device event can then be re-processed - and if successful, a new device event is created. |
D1-InitialLoadIMD | Used for initial measurement upload. The IMDSeeder business object is used to determine the type of initial measurement business object to instantiate when receiving usage readings from a head-end system. |
Inbound Web Service Name | Description |
D4-ConnectLoadNotification | Connect Load Notification |
D4-DecommMeterNotificationXAI | Meter Decommission Notification |
D4-DisconnectLoadNotification | Disconnect Load Notification |
D4-ReadBDNotificationXAI | Read Billing Data On-Demand Notification |
D4-ReadingATMConfigNotification | Get Response Initiate Read By Meter Number |
D4-ReadLoadStatusNotification | Read Load Status Notification |
D4-ReadLPNotificationXAI | Read Load Profile On-Demand Notification |
Message Sender | Description |
D4-ADDMETREQ | Add Meter Request |
D4-CONLOAD | Connect Load |
D4-DECOMMIS | Device Decommissioning |
D4-DISCONLD | Disconnect Load |
D4-HNLBATEVT | NES Handle Batch Event |
D4-HNLBATUSG | NES Handle Batch Usage |
D4-RDLOADST | Read Load status |
D4-READBILLD | NES On-Demand Read (Scalar)(2) |
D4-READLP | Read Load Profile |
D4-RETMETID | Retrieve Meter Identifier |
D4-RETRIEVE | Retrieve Meter Information |
D4-ReadBill | Read Billing Data |
D4-SETATMCFG | Set ATM Configuration |
