Inbound Web Service | Description |
D1-BulkRequestHeader | Bulk Request Header |
D1-BulkRequestUpdate | Bulk Request Update |
D1-BulkResponse | Bulk Response |
D1-DeviceEventSeeder | Used for upload of device events. The Device Event Seeder business object serves as a means of adding device events both from outside the application and from online. Its pre-processing algorithms determine the device event type - which in turn defines the device event BO that should be used to create the device event. If a device event type can't be determined, the device event is created using this BO. Such a device event can then be re-processed - and if successful, a new device event is created. |
D1-InitialLoadIMD | Used for initial measurement upload. The IMDSeeder business object is used to determine the type of initial measurement business object to instantiate when receiving usage readings from a head-end system. |
D1-DeviceStatusCheck | Device Status Check This service is invoked by the integration layer to instantiate a Device Status Check command. |
D1-InitialLoadIMD | Used by OSB to instantiate an IMD This inbound web service is used by OSB to instantiate an Initial Measurement Data for incoming interval usage in the Sensus format. |
D1-RemoteConnect | Remote Connect This service is invoked by the integration layer to instantiate a Remote Connect command. |
D1-RemoteDisconnect | Remote Disconnect This service is invoked by the integration layer to instantiate a Remote Disconnect command. |
D6-ConDisconStChgNotification | Initiate Connect Disconnect response. Retrieve response from the Initiate Connect Disconnect command. |
D6-OutageDetectionEventNotification | Initiate Outage Detection Response Retrieve response from the Initiate Outage Detection Event Notification command. |
D6-ReadingChangedNotification | Reading Changed Notification Notification that a Sensus device reading has changed. |
D6-UnsolicitedEventNotification | Unsolicited Event Response Retrieve unsolicited notifications when an event triggers an alarm on the meter. |
Message Sender | Description |
D6-CONDISCON | Sensus Initiate Connect/Disconnect |
D6-INTOUTDET | Initiate Outage Detection Request |
D6-InitMID | Initiate Meter Read By Meter ID Outbound Message |
