Business Object Name | Description |
D8-AddMeterDefinitions | Itron - Add Meter Definition (Commission) |
D8-DeregisterMeter | Itron - Deregister Meter (Decommission) |
D8-DetectLoadSideVoltageByMtr | Itron - Detect Load Side Voltage |
D8-DetLoadSideVoltageMtrRslt | Itron - Detect Load Side Voltage Result |
D8-DisconnectMeter | Itron - Disconnect Meter (Remote Disconnect) |
D8-DisconnectMeterResult | Itron - Disconnect Meter Result |
D8-PingByEndpoints | Itron - Ping By Endpoints (Device Status Check) |
D8-PingByEndpointsMDResponse | Itron - Multi-Device Ping Response |
D8-PingByEndpointsMultiDevice | Itron - Ping By Endpoints Multi-Device |
D8-PingByEndpointsResponse | Itron - Ping By Endpoints Response |
D8-ReadDisconStateByMtr | Itron - Read Disconnect State |
D8-ReadDisconStateMtrRslt | Itron - Read Disconnect State Result |
D8-ReadInterval | Itron - Contingency Read (Interval) |
D8-ReadResult | Itron - Contingency Read Result |
D8-ReadScalar | Itron - Contingency Read (Scalar) |
D8-ReconnectMeter | Itron - Reconnect Meter (Remote Connect) |
D8-ReconnectMeterResult | Itron - Reconnect Meter Result |
Itron OpenWay Flat File Field | Device Event Seeder BO Element | Comments |
Transaction ID (from Header record) | External Source Identifier | This is the file name. |
Device Identifier | External Device Identifier | |
Event Name | External Event Name | |
Event Creation Date/Time | Event Date/Time | |
Device Type | External Device Type | This element has no real bearing on the device type within MDM/SGG. Its valid values include (although the element itself is free-form): Meter Collector Router |
Service Location ID | External Service Location ID | |
Communication Module Serial Number | External Communication Module Identifier | |
Event Category ID | External Event Category | |
Event Severity | External Event Severity | Valid values include (although the element itself is free-form): Alert Information |
Status Value | External Status Value | This represents additional information that relates to the event itself. |
Status Date/Time | External Status Date/Time | The date & time at which the additional information referenced above had occurred. |
