Inbound Web Service | Description |
D1-BulkRequestHeader | Bulk Request Header |
D1-BulkRequestUpdate | Bulk Request Update |
D1-BulkResponse | Bulk Response |
D1-DeviceEventSeeder | Used for upload of device events. The Device Event Seeder business object serves as a means of adding device events both from outside the application and from online. Its pre-processing algorithms determine the device event type - which in turn defines the device event BO that should be used to create the device event. If a device event type can't be determined, the device event is created using this BO. Such a device event can then be re-processed - and if successful, a new device event is created. |
D1-DeviceStatusCheck | Device Status Check This service is invoked by the integration layer to instantiate a Device Status Check command. |
D1-InitialLoadIMD | Used by OSB to instantiate an IMD The IMDSeeder business object is used to determine the type of initial measurement business object to instantiate when receiving usage readings from a head-end system. |
D1-RemoteConnect | Remote Connect This service is invoked by the integration layer to instantiate a Remote Connect command. |
D1-RemoteDisconnect | Remote Disconnect This service is invoked by the integration layer to instantiate a Remote Disconnect command. |
D8-DetLoadSideVoltageMtrRslt | Itron - Detect Load Side Voltage by Meter Result |
D8-DisconnectMeterResult | Itron - Disconnect Meter Result Service |
D8-InterrogateByGroupResult | Itron - Interrogate By Group Result XIA |
D8-PingByEndpointsMDResponse | Itron - Ping By Endpoints Multi-Device Response XAI Inbound |
D8-PingByEndpointsResponse | Itron - Ping By End Response inbound web service |
D8-ReadDisconStateMtrRslt | Itron - Read Disconnect State by Meter Result Service |
D8-ReadResult | Itron - Contingency Read Result |
D8-ReconnectMeterResult | Itron - Reconnect Meter Result Service |
Message Sender | Description |
D8-RemoteCon | D8 Remote Connect |
