Inbound Web Service | Description |
D1-BulkRequestHeader | Bulk Request Header |
D1-BulkRequestUpdate | Bulk Request Update |
D1-BulkResponse | Bulk Response |
D1-DeviceEventSeeder | Used for upload of device events. The Device Event Seeder business object serves as a means of adding device events both from outside the application and from online. Its pre-processing algorithms determine the device event type - which in turn defines the device event BO that should be used to create the device event. If a device event type can't be determined, the device event is created using this BO. Such a device event can then be re-processed - and if successful, a new device event is created. |
D1-InitialLoadIMD | Used for initial measurement upload. The IMDSeeder business object is used to determine the type of initial measurement business object to instantiate when receiving usage readings from a head-end system. |
D1-DeviceStatusCheck | Device Status Check This service is invoked by the integration layer to instantiate a Device Status Check command. |
D1-InitialLoadIMD | Used by OSB to instantiate an IMD This inbound web service is used by OSB to instantiate an Initial Measurement Data for incoming interval usage in the Generic format. |
D1-RemoteConnect | Remote Connect This service is invoked by the integration layer to instantiate a Remote Connect command. |
D1-RemoteDisconnect | Remote Disconnect This service is invoked by the integration layer to instantiate a Remote Disconnect command. |
DG-ConDisconStChgNotification | Initiate Connect Disconnect response. Retrieves asynchronous response from Initiate Connect Disconnect command. |
DG-OutageDetectionEventNotification | Initiate Outage Detection Response Retrieve response from the Initiate Outage Detection Event Notification command. |
DG-ReadingChangedNotification | Reading Changed Notification Notification that a device reading has changed. |
Message Sender | Description |
DG-COMM | Generic Adapter Commission |
DG-DCOMM | Generic Adapter Decommission |
DG-INTOUDET | Generic Adapter — Initiate Outage Detection Request |
DG-XAISender | Commission / Decommission Sender |
